presque fini (nouvelles project ,1157 efe turbo)
manny
Message par manny »
viewtopic.php?f=5&t=20702&p=359125#p359125
Comme je l'ai promis lorsque j'ai présenté
:VroumVroum06: :VroumVroum06: :ico_yeah4:
http://img89.imageshack.us/img89/2471/photo075p.jpg
frame 750 88 (first in europe number 100006)
engine 1127 from a 89
83 mm wossner piston 12.5-1
carillo rod
balance and lightened crankshaft
light ported head (original valve size) (i have also ported one with 30 /27 and original dot head)
750 88 cams (i have also yoshi stage 1 and 2)
slotted cams sprocket
5 speed gearbox from 11 92 (undercut)
barnett clutch and spring
headers 4-2-1 f1 endurance replica/f1 silencer
carb mikuni tmr 41 with mjn yoshimura kit (from a 11 W)
with adapter and k-n filters
dyna 2000 (38degree curve 2 i have also a complete dyna 4000 ,but at the end i prefer use 2000 )
passenger foot step and lower crash pad from gsg moko
upper crashpad from unknow french company (buyed 10 years ago)
complete tail/seat rear light from rgv gamma 250
tank 750 91
front fairing is from speer racing for 11 91-92 with 750 91 mont frame and light (also stand light)
front wheel /fork gsxr 750 srad (fork with ohlins mod)
triple from: lower 750 94
upper abm superbike cnc for 750 93
original steering damper
gsxr 750 r rear shock
rear wheel bandit 1200
brake disk from srad 600 (at rear i use brake hanger from a slabby for a 220 mm disk)
swing from 750 93
caliper r1 with adapter buyed on ebay
radial brake pump gsxr 1000 k7
clutch pump kawa zx7r
pazzo racing lever
handlebar and balancer from rizoma
tank cover and bag from bagster
scottoiler
dashboard from 1100 w 93 (water thermo become oil thermo)
garmin zumo 550 (my tacho)
think is all
subframe have no mod so i can come back with old fairing
frame was repolished this week end
and fairing move up and more in front (2.5 cm)
fit also different upper crash pad
next step (when i have time !!!)
dyna coil
nology cable
different driver footrest
k8 1000 rear shock
earles oilcooler
and more
polish front wheel (when i dont fit 1000 k9 fork)
repaint all body
carbon front mudguard
when we finish fuel injection system ,test and dyno on twin turbo 11
i plan to do the same job on this bike....... (next winter for sure)
Modifié en dernier par manny le 03 déc. 2010, 16:30, modifié 2 fois.
Re: presque fini
faudra m'expliquer un jour l'intérêt des étriers radiaux sur une fourche à supports non radiaux.
BuZz
Re: presque fini
Message par BuZz »
Je pense que c'est purement esthétique Max. :wink:
BBZ
Re: presque fini
Message par BBZ »
y a du beau gratin quand meme faut le dire, reste à voir si c est lui qui l as fait lui meme, je serai curieux de savoir combien elle developpe maintenant
noir mat :ico_yeah4:
manny
Re: presque fini
Message par manny »
par rapport aux étriers à six pistons Tokico
de ce changement que j'ai trouvé:
miglore puissance de freinage
une meilleure évolutivité du freinage
l'esthétique?
étaient nouveaux
:Inclassable12:
Re: presque fini
hé ! pas mal,,,et original cette tête de fourche :Demon07:
manny
Re: presque fini
Message par manny »
dan70
Re: presque fini
Message par dan70 »
ptain j aime bien le turbal !!!!
chouette l installation :Demon07:
11 r 92
manny
Re: presque fini
Message par manny »
dan70 a écrit :ptain j aime bien le turbal !!!!
biturbo....... :burningsmilie8bx:
dan70
Re: presque fini
Message par dan70 »
oh ptain le truc de ouf !!!!!!!
l installation des turbals..........j adore .....super boulot !!!!!!!!
11 r 92
gésexixairwuile
Re: presque fini
Message par gésexixairwuile »
Salut Manny superbe tes motos tu est un vrai passionné du streetfighter à ce que je vois :Demon07: Dit moi en Allemagne les pièces du catalogue GSG Mototechnik, je suppose que tu peux t'en procurer facilement? Peut tu m'indiquer les prix des motordeckel pour un gsxr 1100 de 1992 s'il te plait merci! :Alcooliques21: J'adore les pièces moko mais je ne possède que le catalogue numéro 7, tu as le dernier catalogue?
Vielen Dank deines interesses
manny
Re: presque fini
Message par manny »
http://www.gsg-mototechnik.de/
132,00 num.1
352,00 num.4
418,00 num.2
267,00 num.3
Ces couvertures sont mieux
http://www.psycleworkz.com/shop/categor ... =cid%3D%26
:ico_yeah4:
520 euro pour les 4
gésexixairwuile
Re: presque fini
Superbes mais pas donné les Moko, mais les carters noirs sont pas mal et moins chère! Tu as quoi sur tes motos? Les black signature series c'est allemand?
manny
Re: presque fini
Message par manny »
Non, la société et en anglais
pouvez les obtenir en anodisé ou en or rouge noir bleu or alluminum natur
sur mon moto, je crois,dans l'avenir ($ :Chut08: )
gésexixairwuile
Re: presque fini
Je vois que l'on est tous pareil la moto c'est un loisir qui coûte cher mais quand on est passionné...
