GSX-R1 by Tomcat
Re: GSX-R1 by Tomcat
suzuki only a écrit :je viens de me faire de nouveau les 44 pages et je suis toujours autant bluffer par ton travail moi je te dis un grand BRAVO et vivement la suite
: :admin: :admin: :admin: :admin: :admin: :admin: :Demon12: :admin: :admin: :admin: :admin: :admin: :admin:
Ah !! c'est gentil copain :ico_yeah4: :ico_yeah4: :ico_yeah4: :ico_yeah4: :ico_yeah4:
j'appécie :Alcooliques03:
feiong a écrit :Ben ouais Tomcat,
Mais faudrait peut etre y retourner,on attends la fin ,nous !!! :Inclassable12:
ça vient, ça vient :Super14:
debaser
Message par debaser »
I have nearly done as many kilometers as you have had visits.... :VroumVroum06:
debaser
Another to make you feel better :Alcooliques03:
Hello debaser
if I have good memory I have ever see your bike on Sikestbikes ???
We have the two GSXR-1 the world :Demon12:
You have make good job, and congratulations for your kilometers :1er:
:Alcooliques03:
debaser
I don't mind that you copied my idea :wink:
How soon till yours is up and running? I am going to supercharge mine with a small blower from the new mini cooper. I am also going to turbo an 1100 motor and find another frame. I might try and keep the 1100 looking original.
gufournier
Message par gufournier »
OUA la piscine!!!!!!!!!!!!
What the magnifique swimming pool :wink:
rebel
Message par rebel »
j'aime beaucoup mais il aurait pu mettre une tdf
debaser a écrit :I don't mind that you copied my idea :wink:
I try to run in one or two month, I have holidays to finish it, the problem is the money :Grrrr03:
I see you want charge the engine with a lot of horses :Demon07: don't forget post the pictures :ico_yeah4:
:Alcooliques03:
antoinet111
Message par antoinet111 »
Yeahhh, if you create a monster like that, put a lot of photos!!! :Super14: :Super14: :Super14:
Voila le programme du WE, adaptation du bouchon popup, grace à ces rondelles découpées au plasma et qui vont être soudées au tube et au résé puis mastic.
puis passage des fils du comodo, dans le guidon
et enfin moulage de la grille alu à la forme de l'ouverture du réservoir
gex01
Message par gex01 »
oooeeeeeeeeennnnnnnnncul..............
t as tout pour faire bien?
je bave :Inclassable12:
voila ! les vis servent à plaquer la rondelle du dessous pour que ce soit hermétique, les vis tete fraisées seront plus noyées et je souderai et aprés mastic pour lisser le tout, mais avant il faut que je fasse mettre le tube au bon diametre pour enboiter le bouchon.
gufournier
Punaise mon gas, tu vas nous faire une merveille.
Dépéche les beaux jours arrivent!!!!!!
gufournier a écrit :Punaise mon gas, tu vas nous faire une merveille.
merci mon guguf :Demon12: tu m'étonnes que le soleil me crame les neurones, ça me démange grave surtout qd tu bricole et que tu entends les autres se tirer des bourres devant la maison :Beurk02: :Grrrr03:
